Prakash12345
Junior Member level 2
Wire transmission(15 mtrs) to send data & control signals for cascaded shift register
I'm trying to send 4 kbps data from micro-controller(sender) to cascaded shift register IC(receiver).
In this scenario distance between micro-controller and shift register is 15 meters. On receiver side 512 shift register is arranged in cascading manner. I decided to use 15 meter wires with DB-15 connector with 15V and for data transmission MOSFET used on sender side. 15V is require to give power to other devices, other than data and control pins in DB-15 connector is used for other purposes. On receiver side 15V power source will be available and this 15V is powering the micro-controller.
My main doubt is, is there any data loss occur when we try to send data for 512 shift register arranged in cascade at 4 kbps over 15 meters of wire?
And which MOSFET is suitable for data transmission and idea for circuit designing in MOSFET side?
