bubulescu
Member level 3
Hello,
I'm in a small dilemma. I'm making a model of a Rogowski current transformer in LTspice and I'm done with it, except I don't know how to model the capacitance between the wire running through the toroid. I have the inner resistance, capacitance, almost all needed for the secodary inductance, but I would like to model this one, too. Now, I know it is virtually negligeable, but for inner radii small enough, the effect is present, albeit in small numbers.
I've attached an image which is suppopsed to replace a thousand words, English not being my native language. You're looking at a simplified section view of the left half: in the left side there's the circular section of the bobbin and to the right the conductor. What I want is to find out what is the medium distance (marked with x) between the wire running through the center of the bobbin and the inner surface of the bobbin. Having that, I can calculate, or approximate close enough, the parasitic capacitance, as being a conductor in a cylinder. The formula, in this case, would be:
where R is the outer radius, Ø the conductor's diameter and l the length of the conductor. Of course, the condition would be for the conductor to run through the center of the toroid, but that can be ignored since it's a simulation.
So, mathematics not being my strong point, I am now asking for your help.
2×π×ε0×l/ln(2R/Ø)
