ahmad_abdulghany
- Joined
- Apr 12, 2005
- Messages
- 1,206
- Helped
- 102
- Reputation
- 206
- Reaction score
- 22
- Trophy points
- 1,318
- Location
- San Jose, California, USA
- Activity points
- 11,769
Hello
I have a Dell Inspiron 6000 laptop and i faced a problem that couldn't be solved!
when i got it, I expected a standard Windows XP media and separate applications CD that can let me pick and choose the software I want to install. What I got was only a restore CD that apparently sets up the machine in the original factory condition with all the junk software.. but what i had known later that this CD uses a 4GB special drive on the HDD containing backup data to restore..
My problem is that I wanted to split hard disck into many partitions and i used partaion magic for this issue and i did the following :
1. Delete the backup special partition (I didn't know what was it)
2. Creat Partition on the deleted space (empty now)
3. Delete another small partion (i think it was also important)
4. Creat Partion
5. Merge all these partions into one 57.3GB partion
6. Tried to split but failed
then i pressed apply
--> Windows restarted --> it applied then .. error message appered and it stopped then when i restarted .. no windows or anything but only a message : Press Alt+Ctrl+Del to restart ..
I tried to re-install windows using backup .. but i found it is not found (deleted)
then, I tried to install from my own Windows XP SP1 or SP2 .. when booting from CD the line: setup is inspecting your hardware appears then vanishes and ... nothing after that! only a black screen!!
I don't know what to do? Can anyone help me out? Please please please !! be fast
it is too urgent!
Thank you very much
4. Creat Partion
it is too urgent!
Thank you very much
