If you apply the nominal input voltage, the transformer will consume a high current, and burn quickly, if you keep it powered.
If you know a way to operate a transformer without connecting it to a voltage source (e.g. mains power supply), I'll think about to the specific problem.you are talking about voltage i can't understand your reply please explain it.
If part of a primary winding of a transformer were accidentally short-circuited what will the immediate effect on transformer.
Thanks for the reply but i can't understand it properly.If part of the primary is shortted then the net effect is reduced number of turns on the primary causing more flux on the core (core can saturate loosing its magetic properties) & more peak primary current which will damage the winding after few Secs / min depending upon how many turns are shorted out.
