D.V.Subramanian
Newbie level 2
- Joined
- Mar 10, 2010
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Chennai, India
- Activity points
- 1,307
I’m fabricating a permanent magnet generator for a Vertical Axis Wind Turbine. This is expected to give a 3 ph. o/p (vol tage and frequency varying with windspeed) which after F.W rectification is expected to give 30 to 50 volts D.C depending on the prevailing windspeed . Now I have to take the Battery / inverter route for converting this to 220 V / 50 ~ single ph. A.C for domestic use. I’m designing for about 500 watts max.
Is there any method or off-the-shelf equipment to convert the variable frequency and variable 3 phase voltage of the PMG directly to 50 cycle 220 volts A.C skipping the battery charging/ inverter route ?
Subramanian
Subramanian
