owen_li
Full Member level 3
design compiler physical compiler
In our traditional design flow, we oftern use Design Compiler to make an sythesis. However, because of its unaccurate wire load model, the constraints are usually not fit for our design. Physical Compiler also can do synthesis and can estimate the physical imformation of the design without wire load model. So, will Physical compiler replace Design Compiler.? Which tool is more superior?
