cupoftea
Advanced Member level 6
We have two MBR6045 diodes in parallel at the output of a 24V, 50A PSU.
They are 7cm apart, and both screwed in to the same 11cm x 11cm aluminium plate which is 1.5mm thick.
Do you think it would help to have them closer together? or is 7cm close enough that there temperatures will be the same? (we want to avoid one gettign much hotter than the other and shipping the majority of the current)
MBR6045
MBR6045
