Mr. Grey
Newbie level 6
wilkinson divider design
I need to design a Wilkinson power divider with a power division ratio of 1.96 at frequency 2.4 GHz. It needs to achieve good impedance matching with the return loss at each port needs to be less than 15 dB and mutual isolation between two output ports needs to be less than -20 dB at 2.4 GHz. The characteristic impedance is 50 ohms. It is to be realized by using microstrip lines. The PCB board is FR4 substrate has a permitivity of 4.4, loss tangent 0.025, substrate thickness h mm, metal thickness 0.035 mm. The design and simulation is to be done in EWR Micowave office.
Can anyone help me on this?
How to i calculate the input length of the microstrip?
Is there any link that can answer the question above?
Please show me how to do it.
Thnx.
Thnx.
