zejulios
Newbie level 6
Hello,
In my project I have to use ethernet network, either by ethernet cable, or Wifi.
I'll use HTTP client, since my board will access a webpage.
I need two modules (one with ethernet, other with wifi) that uses the same firmware, and comunicate with my micro (UART/SPI/I2C), so I can easly change from a wireless to wired system without too much code change.
It should be as small and cheap as possible, and it will work on batteries.
What are the suggestions?
Thanks,
Thanks,
