Wierd problem with P*OTEUS and COFF file!
branek
Junior Member level 3
SERBIA
solair.eunet.yu
Hello,
I ask a question about this strange behavior of PROTEUS some time ago, and now I have it again!
I can't debug interrupt routine! On picture below you can see that on the left side there is no ROM addresses, so I can't put a break on the line!
Anyone else have similar problem!?
I am using P*OTEUS 6.2SP5 and HITECH PI*C 8.01PL3!
// Moved from PCB Routing & Schematic Layout software & Simulation
I'm pretty sure this has to do with compiler optimisations. In the first instance you should set all optimisations off - if this doesn't work then send me all the files at Labcenter (including the source) and I'll set it up here.
Iain.
