2000
Member level 5
hf transformers
hello friends,
I'm actually wroking on a 2.5W HF power amplifier using the 2sc2166 transistor in a A class topology. The output power is about 2.5W. The problem is... to match the output impedance of this stage to a 50 Ohm load, I'm supposed to use a 1:4 (Z) transformer and that should mean that the voltage in the secondary is supposed to be the double the input voltage in the primary of the tranformer... but its simply the same!!! what is going on? I simply cant work in the A class but I'm being forced in the AB class... the amplitude of the output signal is too large and the transformer is unable to low it in the primary...
Anybody could help me? any interesting site about the topic?
regards,
2000
hello friends,
regards,
2000
