wide range Resistance measurement with opamp
themaccabee
Full Member level 4
Full Member level 4
I need a circuit to measure resistance between 1K to 240K..
I presently use an opamp based circuit in which a noninverting amplifier with feed back resistor is given as the unknown resistor & a reference voltage given at input.. the output voltage is measured by an ADC..But this cant measure wide range as specified above..coz the opamp gets saturated.. any ideas??
The easiest way is to split it in sub ranges, 2.5k, 25k, 250k.
If this is not acceptable, the solution is more elaborate. You need at least a 12-bit ADC to cover that range. Assuming a reference voltage of 2.5V, the ADC will measure between 10.4mV to 2.5V depending on the resistor to be measured. At 10mV the measurement precision will be 5.7%. To improve the precision you need a higher resolution ADC.
This second method works but you need to manage noise: have good grounds, heavy filtering, decoupling caps for all the active components.
