Eugen_E
Full Member level 6
20 mhz vco
Hi all!
I want to design a wide range (2-20MHz) discrete VCO, as part of a PLL frequency synthesis and I need some ideas.
I think there are few ways to do this:
1. A oscillator controlled with wide range varactor diodes ---but I can't find special varactors to use---
2. Mixing 2 higher frequency signals, for example one at 100MHz and the second from a 102-120MHz VCO (controlled with "normal" range varactors) ---but the schematic is more complex and the output signal contains more harmonics---
3. Using a ring oscillator, which is suitable for IC design.
So, who can help me with some ideas in designing this VCO with general purpose parts and a moderate complexity schematic? I appreciate your help!
Thanks in advance!
Best regards,
eugen
Hi all!
Thanks in advance!
Best regards,
eugen
