Why we use raised root cosine or RRC filtering?
bizoo
Member level 5
Member level 5
i have a question about why we use raised root cosine or RRC filtring,
i am implementing BPSK, so if i have 1 i will send a cosine wave and if -1 i will send a 180 shifted cosine wave,
RRC is done to make signal less vulnerable to inter symbol interference, but what i am sending on the channel is cosine wave, i never used square pulses on the channel so why should i use RRC any way,
but the text seems to suggest to use RRC before sending any thing ont he channel
ne answers!
raised root cosine
actually when you don't use RRC , you are using the rectangular pulse shaping by default.
when using the RRC , the pulse shape is not rectangular ,and each symbol period is filtered with the RRC filter , then the resulting pulse shape is applied to the sin & cosine waves .
regards
Re: raised root cosine
HMM the last part You said taht pulse has a RRC shape and then this shape is applied on sine and cosine waves, i can visualize that :(
Can You please provide me some image of that some where, any website? any links,
i just want to see the difference in waveforms send on the channel when using a square pulse and compare it with RRC generated waves
check this out
Inter Symbol Interference (ISI) and Raised cosine filtering
hope this helps you
