JiL0
Member level 1
CMFB
Hope someone can help. Designing an differential amplifier.
I dont really understand the problem that necessitate the use of CMFB circuit and what problem will arrise without the CMFB circuit. Does it mean that if we dont have CMFB, the output voltage will have a DC error? Does this problem happen only when we are using the amplifier in feedback?
I understand from reading razavi's book that the problem arrises from the error mismatch between the p-type current source and the n-type current source (does this error arrise due to the differenct input voltage or issit due to fabrication prob?). THis causes voltage error at the output. By using CMFB, we sense this error and minus this error from the input. And this is done by re-adjusting one of the current source so as this will not be any mismatch. Is my understanding correct?
