idmond
Newbie
“In AM synchronous demodulation, Why we don’t divide the received signal, m(t)coswt, by cos(wt) using a simple divider circuit instead of multiplying by cos(wt)?”
I asked this question to two professors and I got different answers:
#Professor 1 Reply:
"For your scheme to work you must know exactly what the frequency w is that the transmitter is using, which tends to drift. So try your scheme with dividing
by cos (w+delta)t and see whether you can recover the signal."
#Professor 2 reply was:
"we don't use the division scheme for two reasons:
a- In the real world, noise is added to the received signal and it is going to look like this, m(t)coswt+n(t). If you then divide by coswt, you will get, m(t)+n(t)/coswt, and since the cosine function ranges from -1 to 1, thus for values of cosine less than 1, the noise term will increase much more, so you will get poor SNR.
b- When the cosine function goes to zero, you will divide by zero in this case, so what?"
I am now confused more than ever:-?. which one is true?
#Professor 1 Reply:
