T
treez
How an ESD mat should operate:
multilayer:
* the top layer is relatively high ohmic. It prevents high current flow when a PCB is placed on the mat with line voltage applied. --> no smoke
It also reduces ESD currents due to its high impedance.
* then there is a higher conductive layer. It is used to lead ESD currents to the earth connection. It also keeps areas of high potential small on the top layer (this prevents you from being electrocuted).
--> both layers help to keep ESD damage low: Low currents, relatively fast voltage decay, small areas, currents fed to GND.
* Maybe there is an additional layer (at the bottom) between this higher conductive layer and the desktop surface. It depends on the mat.
Thanks, we really don’t care about the danger of being electrocuted through a conductive ESD mat…..we will just be careful….the highly conductive ESD mats are far cheaper so we want to use them.
Our highly conductive ESD mat has a metal push-on connector to a yellow earthing plug, and the lead to this yellow plug has a high resistance of 2 Megohms…so there is the high resistance needed…and we simply wont be able to get high current flowing in our conductive esd mat because the 2meg resistance to earth in the lead of the earthing plug will stop this?……….as you know, all current flows in loops, and since the loop of current that contains our conductive esd mat contains 2 meg of resistance, then we simply won’t get high currents when highly charged esd festered objects touch it. Surely you agree?
https://www.farnell.com/datasheets/...MI6vvDrJ6J1wIVEBIbCh2irgg_EAQYASABEgIQxvD_BwE
...the above is a bona fide esd mat an is only 10kohms per square metre........i dont think this product woudl be for sale if it was unsuitable?
