Why Volatile keyword in Embedded C?
Surender Reddy
Full Member level 2
Full Member level 2
Bangalore, India
What is the necessity of using volatile keyword for embedded applications?
Can any guide me with some example?
Use this keyword within variable that accessed inside and outside interrupt at the same time.
even the global variable also does the same without volatile.
what is the important of volatile?
How volatile keyword avoid optimization techniques by the compiler for a variable?
Just lets compilier fully copy the stack including this variable before enter interrupt routine.
assume you have an timer interrupt handler which sest a global variable every second, e.g.
volatile int second=0; 	// set every second
void __attribute__((__interrupt__, __shadow__)) _T1Interrupt(void)
/* Interrupt Service Routine code goes here */
IFS0bits.T1IF = 0; 							//Reset Timer1 interrupt flag
second=1;
int main(void)
startTimer();
second=0;
while(!second);      // wait 1 second
    ...                // code executed after a second
in main second is tested in the while() statement which executes every second
the problem is that if second is not declared volatile an optimising compiler will look at
second=0;
while(!second) ;     // wait 1 second
see that second is initialised to 0 and remove the while() statement - thus whole sections of code can be removed
the volatile keyword tells the compiler that the variable may be altered outside the current context and code should not be optimised
for more detail see
https://en.cppreference.com/w/cpp/language/cv
It is a good practice to put the variables inside the routines where are supposed to be used.
This makes the program more organized, avoiding spread a big list of variables at the main().
Thanks for the reply....
Is there any separate memory for these volatile variables? where these are stored?
volatile doesn't allow to make perform optimization by compiler on the volatile variables, which increase the length of the code (some).
This is one drawback of volatile.
I am right?
second=1;
int main(void)
startTimer();
second=0;
second=0;
for more detail see
I am right?
I assume volatile variables would be allocated on the heap along with other global variables - you could always look at memory maps to check
you would only use volatile in situations where you don't want optimisation, e.g. global variables used to pass information between interrupt routines and other parts of the program
Global variables are allocated in the data memory but you said heap.
Ok, I will check with memory maps for volatile variables.
Anyway, thanks a lot, you cleared my doubt.....
both heap and satck are what you would call data memory
1. heap for permanent (during execution of the program) variables such as global external variables and static variables (defined inside a function) - also dynamic storage allocated by functions such as malloc and calloc
2. stack for temporary data such as automatic variables defined inside function and the information pushed onto the stack during a function call
have a look at
https://www-ee.eng.hawaii.edu/~tep/EE160/Book/chap14/subsection2.1.1.8.html
