paulux
As I am using variable resistance nature of MOS as a tunable resistor in trans. sim, the oscillation occurs when the setting in Hspice "accurate=1" is enabled. When I do not set any option or just use "method=gear", the output just shows few ringings and then stable. I have checked all the op. points during the changing transient. They are all stable(at least 30deg phase margin)....Since there is no DC current flowing through this var-R MOSFET and the gm is found to be zero when .op is used and only rds of several hundreds kΩ is found, is this problem related to MOSFET model inaccurate parameter extraction problem or spice simulation accuracy problem? Which result should close to the real situation? The model I use is level49 MOSFET model. Please kindly help and comment about this.
Or any others comments are highly welcomed
