walkrain
The day, when doing meter measuring, I use magnetic beads for high-frequency signal, through the book, i know when the high-frequency signal through the magnetic beads, the energy can be converted to heat, and losses. But when i calculate it by circuit analysis theory, i found when HF signal through the magnetic beads, only reduce the peak voltage, it can't changes the frequency of the voltage, so, i want to know since it can't change the frequency of the voltage, why i use it ?
