cupoftea
Advanced Member level 5
As 5:48 of this video shows..
..welding a thermouple junction is just about making a circuit out of the two paralleled thermocouple wires, and then connecting this circuit momentarily via a carbon block. The carbon block is needed as it vaporises on contact and so produces an arc due to the air gap thus formed...the arc producing the heat needed to weld the two ends together.
We don't have a carbon block, so will instead use the following graphite pieces..
Since we also don't have the £2500 thermocouple welder, we will simply use the rectified and smoothed mains. We will have a variac to get the right voltage for the best "weld".
Do you know why they use carbon in the video? Its far harder to source blocks of carbon, but graphite is easy and cheap to source.
