Why Unix machines MAC address is only 8 digits?
mesfet
Full Member level 2
Full Member level 2
length of mac address?
Hi All,
I wonder why the MAC address my UNIX machine is 8 digits, I use lmhostid to check, while MAC address of my PCs are 12 digits??
Mesfet+
Re: Length of MAC address
If I recall correctly, Solaris misses off leading zeros on the hex digits - maybe this is why?
Can't check now, I sold my Sun box :(
Cheers,
FoxyRick.
That´s correct...
# /sbin/ifconfig -a
le0: flags=863<UP,BROADCAST,NOTRAILERS,RUNNING,MULTICAST> mtu 1500
        inet 10.0.0.1netmask ffffff00 broadcast 10.0.0.255
        ether 8:0:20:10:d2:ae
What matters is are the ":" (o;
Don´t run solaris anymore to ferify but the above snippet is from a solaris faq...
Today all major UNIX flavours I´m aware of are using 6 octets...(there´s no digits or bytes in networking ;o)
Hi All,
My problem is that I am going to switch from UNIX Cadence to Linux Cadence. Everything works fine, except one software which need server flexlm license and the MAC address in the license file is 8 digits only. Have anyone come across this problem before?
Mesfet+
Why don´t you ask Cadence support to change your valid UNIX license to Linux?
Or can´t you keep the UNIX box running flexlm and connect from Linux box then?
And how does your 8 digits look like? (o;
