why tri-state logic cannot be buffered
rogeret
Member level 4
Member level 4
In the book Advanced ASIC Chip Synthesis Edition 2 ( Chapter 5.4.4), it is said that Tri-state logic is difficult to optimize – since it cannot be buffered.
This can lead to max_fanout violations and heavily loaded nets.
Could Anyone explain it further why it cannot be buffered?
Thx!
Actually, there shouldn't exit any tri-state (nor bi-direction) logic within a digital chip, if you're using cell base design. Tri-state logic can just exit on IO PAD. For tri-state logic within a chip, there will be many headache. And Tri-state logic within a chip can be easily replace by two one-direction logic.
The headache maybe: multi-drive of the same wire, un-drive of the wire, causing metastable of the gates afer that wire. Then may casuing thermo problem because of the un-driven of logic cell input pins.
Maybe its right, because when i use FPGA I cannot see any tri-state except on PAD.
Could u give me some materials about the headache caused by it? I want to know where and why to or not to use it in detail.
There is situation when few drivers want to access a bus. So, when 1 driver accessed, the rest of the driver need to be high-z.
If you have buffer in btwn driver and bus, can you make sure it is high-z?
