Why this topology is called a comparator?
zhangseong
Member level 2
Member level 2
why is this topology is called a comparator ? how the circuit perform , what is the 1st part of the circuit ? is it an inverter?
Re: comparator
Can you please specify where are the two inputs...Of course the last part of the circuit is a cmos inverter....
Re: comparator
maybe the reference voltage is regarded as the MOS threshold.
the first stage is a pre-amplifier stage
Re: comparator
the first stage is the resistively loaded comon source amplifier stage.
comparator
it's a single-Ended comparator. it 's just is a buffer.
the threshold of comparator(not nmos) varies along with process!
comparator
If you need to regard this as comparator, then the trip point is the inverter trip point where it can switch from L to H. Then first stage determines when to turn over when the INPUT is switching from VSS to some point (say, VDD/2) where parallel equivalent resistance of the RDS of NMOS and the up resistor is equal to the trip point of inverter, then the inverter turns from L to H, that's the comparison happens.
Re: comparator
As we know that the trip point of a inverter is VDD/2, then in order to be the trip point voltage, the common source amplier effective dc voltage is designed at VDD/2. Then as the common source dc voltage increase or decrease from VDD/2 will trigger the inverter either to be in logic high or low.
Thx
