hi dears.
i have simulated a simple microstrip line model in HFSS & CST ,but i think the cst response is wrong.
could any one check this files and tell me what to do for getting same response in cst and hfss,please?
Thanks in advanced:thumbsup:
The results might shift a bit given the way you define the excitations on each simulator and given they use different types of solvers (HFSS uses Finite Element Method and CST uses Finite Integration Technique).
Also, the results will shift depending on the mesh definition (especially in CST if you're not careful)
Sorry if my post is too vague, but I was not able to open the files.
I can't open your cst-file, your version is newer. Post a pic of your model in cst with material parameters, boundary condition, port size and mesh settings. Does you get any errors when you simulate?
