henry kissinger
Member level 2
I have a transmission line with characteristic impedance of 75Oohm.
I model it with both TLIN (electrical) and MSUB (physical) model.
using a 5GHZ data generator to check the signal quality. I found that the result with TLIN model is ok. But the result with MSUB model is bad, still got some ringing.
Both model has Z0=75Ohm and the load is also 75Ohm, also the phase difference is the same, which should be impedance matched.
but why there is the difference? why the MSUB model has ringing even though impedance matched?
