Why there are only 13 channels in WLAN802.11b(WiFi) although frequency range is 2.40-2.4835GHz, Bw is 22MHz with 5GHz spacing?
if the space is 5MHz and BW is 22Mhz then thre will be overlaping of channels?
The Cirond paper mentioned in the last link deals with some
overlapping using 4 channels instead of 3 channels (non-
overlapping). Very interesting since use a spreadsheet
for the calculation of interference due to overlapping
channels....Google it if interested.
As an example, for channels 1 and 2(see fig.) the separation
between the center frequencies are 2417-2412 = 5 MHz. Your
confusion is "How would be a separation less than the channel
bandwidth?", right.? The figure answer that.
In reality for the 2.4GHz ISM band the whole banwidth ~ 82 MHz
only accomodate three channels NON-OVERLAPPING of 22 MHz.
