tony_lth
Advanced Member level 5
I designed a X band LNA with FHX13LG from Eudyna. I had already simulated with S-parameters and noise parameters both in ADS and AWR, but I didn't do the momentum simulation. The simulation result is fine, 13dB gain in 9.1G~9.7G and noise figure is about 1.1dB. I designed with Rogers RO4350B 10mil 1/2oz substrate, and all the match stubs is microstrip line, no lumped element except the DC block RF capapcitors.
But when I tested the PCB board, the S11=-0.6dB, and S21=-7.8dB at 9.5GHz. And at 6.5GHz, the S11=-18dB. It seems that the pass band shifted down from 9.5GHz to 6.5GHz.
I want to know:
1. What cause freq shift down?
2. Should I do paste and try to adjust the pass band to 9.5G? I had tried to do so, and I found it's easier to make S21=10.5dB/NF=3.5dB at 6.5G. My objective is NF(max)=1.5dB/S21>10dB at 9.5GHz, I had tried paste 1 hour and the best result is S21=0dB. I will paste carefully later.
3. Should I do the momentum simualtion to verify the result? I am a newbie for momentum.
4. Is it because the discrete of the components from the typical S-paras?
Thanks.
I want to know:
Thanks.
