huytergan
Member level 3
an antenna at the input, followed with filter and lna then soldered to the coaxial cable (without any connector at the board).
When I touch at the output of the LNA region where the decoupling and output matching circuit components are, and also very close to the coaxial cable soldering points(2 ground and 1 center pad), so I might be touching the coaxial cable’s outer conductor(gnd) as well;
i see the oscillation appears at spectrum analyzer. When I dont touch, doesn’t appear. I wonder what does that mean, i prevent the ground connection of the LNA and it starts oscillation? or Rf signal leaks to the DC line?
Thx guys
Thx guys
