ronzam2002
Member level 5
fala said:bread board! that explains a lot of things. Connections in bread board are not reliable at all.yes it will work if it is connected properly but there is a strong possibility that some connections are not ok. I recommend you to check all connections one by one using a multimeter according to datasheet most probably the problem will be resolved.
