kumar_eee
Advanced Member level 3
- Joined
- Sep 22, 2004
- Messages
- 814
- Helped
- 139
- Reputation
- 276
- Reaction score
- 113
- Trophy points
- 1,323
- Location
- Bangalore,India
- Activity points
- 4,677
Why silicon takes 0.7v & Germanium 0.3v for biasing?...
for a diode to conduct current ,applied force(volt) should dominate the barrier potential( potential of depletion region--it's own potential formed due to coupling of two elements p and n)for si, barrier potential is .7 and for Ge it is .3v...so for current flow across the respective elements,applied volt must cross .7 or .3....kumar_eee said:Why silicon takes 0.7v & Germanium 0.3v for biasing?...
electronics_kumar said:for a diode to conduct current ,applied force(volt) should dominate the barrier potential( potential of depletion region--it's own potential formed due to coupling of two elements p and n)for si, barrier potential is .7 and for Ge it is .3v...so for current flow across the respective elements,applied volt must cross .7 or .3....kumar_eee said:Why silicon takes 0.7v & Germanium 0.3v for biasing?...
A Schottky diode uses a metal-semiconductor junction as a Schottky barrier (instead of a semiconductor-semiconductor junction as in conventional diodes).
Muhammad Raza said:.
basically barrier potential indicates the number of holes and electronics combined.
RAZA
