Why power on reset is a must for microcontrollers?
power on reset!
POR will ensure that PC register is loaded with 0 value and other register also loaded with there starting value. There for POR is MUST for MCU.
Re: power on reset!
Most microcontrollers have specs that describe power up ramps for proper initialization of the controller. A glitch on the supply line may very well cause the microcontroller (or some other component) to power-up incorrectly and prevent the system from operating as intended .. A supervisor device solves this problem by holding the microcontroller in reset until the power has reached a stable level.
Quoted from:
"Understanding and Using Supervisory Circuits"
Regards,
IanP
power on reset!
Read data sheet of PIC16F84A. It has given there why POR is required.
