Why output set to high impedance when chip disabled?
wylee
Full Member level 1
Full Member level 1
Malaysia
Normally when we disable/off/sleep/standby an IC, I noticed all outputs are usually set to high impedance state (tri-state) instead of HIGH or LOW.
What is the reasons behind this?
because of power. If you connect a resistor at the output pin, maybe dissapate power
In these modes you want the lowest power dissipation possible. If a pin is high or low it could be drawing current. If a pin is tri-stated, it can't draw any current.
    wylee
