leohart
Full Member level 4
Why the excessive majority carriers diffusion current is ignored?This problem confused me for long,but no explicit answer is given.
For example,an n+/p diode under illumination,to calculate the photo current,we only have to calculate:1)the current generated in depleted region 2)the excessive hole generated in n+ region and diffuse into depleted region and get collected 3)the excessive electron generated in p region and diffuse into depelted region and get collected
For 2 and 3,they are both excessive minority carriers diffsion current,why the excessive majority hole(in p) and electron(in n+) cannot diffuse into depleted region and get collected?Photon generates both hole and electron!
It seems in most time the excessive minority carrier plays a more important role in device,can anyone give me a insightful why about it?
Added after 24 minutes:
One more thing on the above photo diode example:
Seems we are always assuming the any excessive carriers born in depleted region or walk into depleted region become a photocurrent.But why this is it?
The depleted region is just inside the device,for a current,the carriers have to be transfered outside the depletion to the ohmic contact,how does this transmission through the outside neutral region happen????
On the other side,the excessive minority diffusion currents also exist in neutral region outside the depleted region,can this diffusion coexist without disturbing the total current running to the outside world?
