shreyas_patel21
Full Member level 3
hi all,
when we compile a code it generates object file and from those object files executable files are generated in linking process.
why we need object file?
what is the use of object file?
cant it be possible that executable file is generated directly?
after all we are using executable file to run the program.
thank you,
Regards,
Shreyas.
thank you,
Regards,
Shreyas.
