Why numeric_std library
shaiko
Advanced Member level 5
numeric_std vs numeric_std_unsigned
Hello,
Is numeric_std_unsigned a different library then numeric_std ?
If so, when do we need to use it?
Edaboard search does answer the question pretty well. e.g. https://www.edaboard.com/threads/239950/
It's the VHDL2008 replacement of Synopsys std_logic_unsigned, for those lazy engineers that rely on using std_logic_vectors for numeric data, respectively to ease the porting of old VHDL code that uses the Synopsys libraries.
Reactions: shaiko
    shaiko
