shirish heller
Newbie level 5
why do we not use high frequency waves such as X rays , gamma rays etc. instead of radio waves for communication . coz their modulation is easy larger bandwidth,speed and shorter antenna?????
It's bad enough having a label on my DVD player telling me not to look into the laser. It doesn't explain how I'm supposed to fit my head into the disc drawer though. Perhaps they consider going blind is more dangerous than crushing your skull flat !
we could try using something other than X-ray with higher freq. but not dangerous...P.S can we generalize the statement that if the frequency is very high then the wave would certainly be dangerous(because of more energy in it):lol:
The X-ray smart phone seems like a novel idea, imagine holding it to your ear and the other person seeing inside your head, or even worse telling you they can see straight through.
Brian.
Apart from the technical difficulties of dealing with controlled super high frequencies, and the danger of seeing inside my head (it's a dark, dark place!) you should consider why we use X-ray and gamma rays in existing applications. X-rays are used because they are easily blocked by dense objects, thats how they produce photographs to show our insides. Gamma rays are used to sterilize food stuffs because it destroys organic nucleii. Both are very good reasons not to use them. One would have a very short range, the other might kill you. When you quite correctly state that data rate is proportional to bandwidth and that is limited by frequency, you are missing the point that the Nyquist limit is basically two carrier cycles per sample so even at much lower frequencies the theoretical data speed is faster than we ever need.
Brian.
:lol:
Brian.
