miner_tom
Newbie
Having supervised the routing of many boards, I now see that there are capabilities such as in Altium, where it is possible to have a design rule such that the diff pair can "neck down" to a smaller size, to route in a tight area, as in a BGA. These tools also make sure that the characteristic impedance is constant.
My question is, if the diff pair can be made small enough to fit between BGA (or other) balls/pins, then why not keep the diff pair dimensions the same, outside of the area of the BGA? Why not keep the diff pair dimensions the same through out the route? Yes, fab houses have minimum trace widths and gap widths, but if these dimensions can be acceptable under the BGA, then why can they not be acceptable outside the BGA?
Thank You
Tom
Thank You
Tom
