staalker
I'd like to know how it's technically possible that in the time period of few weeks my computer reacted to ON or OFF the desk lamp and ON or OFF the speakers. I tried to find an answer in pc forums but nobody could explain this sufficiently so I want to try it here becouse I think it's related even more to electronics forum. I had just connected two monitors to the pc and always in the evening (without exception every night for a couple of weeks) when I needed to use headphones and switched off the loud speakers my both monitors turned off (light indicator on both changed the colour from green to orange), the computer froze (caps lock light indicator on the keyboard didn't react) and the fans inside the case spun up to the max speed (I'm not sure if every fan, I only know that a graphic card fan did it). The pc was in this state until I reseted it. Then after rebooting I turned on the desk lamp and the same thing happened again. Before I went to sleep I turned off this lamp and if it was before turning off my pc it happened again.. Then in the morning when I turned on the speaker it happened again.. After that when I tried experimentally to switch on the lamp (which was pretty absurd when it was the light) nothing happened. So I switched off the lamp and it happened again. Together I guess it had to happen for at least 50 times (it wasn't a coincidence happening randomly)... Last time it happened when I returned from outside..it was exactly at the moment when I put my phone on the ground in my room. There wasn't any electronical reason from my side. Now it's alright. It stopped spontaneously without any intervention even I didn't change anything around my pc.
I had everything plugged into one power strip but I could run two pcs together there and it worked fine and the freezing thing was happening when I ran only one pc. That means that there was a reserve in power for higher load. So I think it wasn't the problem with low power from the wall. The desk lamp was with 11W fluorescent tube and was plugged into the wall (same the speakers). I'm sure it was happening even I didn't have anything else plugged into the same power circuit.
I have my pc still connected to the same power circuit and I have no problem anymore. Also the power supply still works fine in my pc.
I'm just curious how it is possible that my computer reacted this way.. What is the electronical bond between the lamp or the speakers and the pc? What could be the cause of starting the problem and stopping it? Thanks for any ideas.
