As the number of bits goes up, the tolerance of the resistors must go down. An 8 bit DAC requires tolerances that are 4 times as stringent as a 6 bit DAC.wany said:i am modifying a 6bit R-2R ladder DAC to 8bit DAC. why only add up two resolution , it become not monotonic? thx
Sample and hold the output after the glitch has settled. I did this back in the '70's, before good video DACs were available. It works well.wany said:Are there any methods excpet for theremometric code. And i have another question: why the result of output (analog signal) is bigger and bigger than ideal ,when code from 11111111 to 0000000. thank you
