Terminator3
Advanced Member level 3
Resolution 320x240, but frame rate is very low - about 8FPS. Tried two cameras, two different ways: compiled FPC v4l demo source code and tried mplayer from command line. Same camera gives about 20FPS min in windows. Driver issue? What i can do to improve camera FPS under linux?
update: I tried other notebook with faster CPU and get 14 FPS. But still not >20FPS. Light condition are goood. As can be seen, FPS depends on CPU. How i can get high FPS on atom CPU? I want to attach camera to embedded PC with linux, and able to see good frame rate on low resolution image, like 320x240...
