Why marker shifts as we zoom in or out in Cadence IC5141?
chinboon
Newbie level 6
Newbie level 6
java memory cadence wavescan
Hi everyone. I wish to enquire on something. Well compare to the IC 5033 version IC5141 provides more computational power. Mere changes were that the wavescan calculator interface in IC5033 has been integrated into IC5141. Ok that's the good part :D
Next is the prob part. I notice that the IC5141 marker shifts as we zoom in and out of the waveform. Does anyone knows anything about this? Or should i direct a help mail to cadence support instead :(
Cadence IC5141
Yes, the waveform and calculator are moved to java problem. And it is more unstable than IC5033. However, I can't find any maker shift in the waveform. I using the redhat8 for IC5141
Re: Cadence IC5141
Well i basically telnet into the workstation and used the IC5141. Maybe due to the mass consumption on memory this occur.
Thanks for the information.
Cadence IC5141
are there full tools in ic5141? Or does it need isr
Re: Cadence IC5141
yea thers an ISR 400MB odd.
Cheers,
Gold_kiss
