Why is this PNP showing emitter pin as "GND"
Logic transistors are mostly used in CE configuration (read: common = ground), that's what the datasheet assumes. No assumptions about supply voltage polarity and positive or negative logic.
also data sheet written by engineers straight out of uni with no real world experience - or knowledge of naming conventions ...
Exactly what I was going to say. Noobs wrote the datasheet.
Or the person who wrote the datasheet drives (on the wrong side of the road) a classic old English car that has its battery positive as the ground.
