naiv314
Newbie level 5
This is a DC inverter welding machine I designed. Now I am facing an issue where the IGBTs are prone to damage when the machine is working under load (with a load). The drive control board uses an SG3525 to output two complementary PWM signals to drive a push-pull circuit, which then goes through an isolation drive transformer to drive the IGBTs on the power board. The attached image shows the Vge waveform of the IGBT (Q1).
[Image description: The oscilloscope screen displays the Vge waveform of IGBT Q1 with measurements and annotations.]
