According to the data sheet of this part the base is connected to VCC and then in the notes for each pin they talk about pin 5 being the LNA Output pin.This pin is an open-collector output. It must be biased to
VCC through a choke or matching inductor. This pin is typically matched to
50 ohm with a shunt bias/matching inductor and series blocking/matching
capacitor. Refer to application schematics.
So to your point the VCC is on the base so again why place VCC on the RF OUT PIN other than just to do so because the data sheet said to do it. What does this have to do with open collector output? I thought open collector open was used when you wanted to connect multiple signals on a bus or wire. The only signal I have is RF so why do I need to apply VCC on the RF OUT?
---------- Post added at 23:44 ---------- Previous post was at 23:32 ----------
Like in any amplifier, the transistor collector or drain must be fed a DC current to amplify.
