T
treez
Hello,
Why is the damping resistor in our Bootstrap high side FET drive blowing up?
Schematic attached.
The boss says that when the bootstrap diode of this circuit was using a silicon carbide bootstrap diode, the circuit worked OK. Then that SiC diode went obselete, so he changed to the US1M ultra fast bootstrap diode, and ever since then, the damping resistor keeps blowing up. (the bootstrap diode footprint is SMB, and we are limited to using whatever fits on that footprint for the replacement)
The SMPS being driven is a 5kW Phase Shift Full Bridge converter with an input voltage of 564Vpk (the output of a three phase rectifier)
US1M diode datasheet:
ADuM4223 datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADuM3223_4223.pdf
UCC27322 datasheet:
https://www.ti.com/lit/ds/symlink/ucc37321.pdf
{do you reckon its got something to do with the bootstrap capacitor being too large (10uF), and so at start-up, when this cap isn’t yet fully charged up, the bootstrap diode is still significantly conducting when it suddenly gets reverse biased, and then the reverse recovery damages the said resistor?)
Schematic attached.
ADuM4223 datasheet:
UCC27322 datasheet:
