Why is it possible for narrowband FM and AM to have a similar spectrum?
leoren_tm
Advanced Member level 1
WHy is it possible for NBFM and AM to have similar spectra?????
Re: narrowband FM
A couple of lines may not sufficiently explain this issue to you but this text should:
"From Amplitude Modulation to Frequency Modulation"
Regards,
IanP
Re: narrowband FM
thx men.....
need more info/......
Re: narrowband FM
If you are after simpler explenation here it is:
The Deviation Ratio (DR) is defined as the ratio of the maximum deviation of the FM signal to the maximum modulating frequency.The DR for NBFM is restricted to values between 0.5 and 1.0. By holding the DR to such small values, only the carrier and the first sideband are of significant amplitude .. see picture below ..
When only one sideband and the carrier are transmitted, the NBFM signal occupies the same bandwidth as an AM signal ..
Regards,
IanP
Re: narrowband FM
how about on AM????
Re: narrowband FM
both will have upper and lower side band..if you look at the expression for both AM and Narrow FM ...they will differ from each other by means "sign" ( + or -) in the expression..
yet to be explored...
Re: narrowband FM
Amplitude Modulation bandwidth can be considered exactly two times the highest frequency of modulation ..
Reference:
Regards,
IanP
Re: narrowband FM
Is it NBFM or FM it doesn't matter. Both are frequency modulation. Difference is different modulation index or simply degree of modulation. At NBFM the modulation is "weak". And in this case the spectrums of FM and AM are similar. And that is a fact. You can prove it mathematically.
Re: narrowband FM
CAN YOU SEND ME a mathematical solution for it?? plssssss
Re: narrowband FM
It looks like you have bothered to read the link that was given to you before ..
All mathematics is there ..
Regards,
IanP
Re: narrowband FM
ib read it!!!!!!!
but not much
narrowband FM
as a similarity both will have same bandwidth and number of side bands
