We have had a 300w, 200khz buck converter designed for us for our 170degC ambient environment. (vin = 120-400vdc, vout=100vdc) The current signal to the current mode controller is via a current sense transformer and not a resistor.
Why have they wound the current sense transformer on a
split section bobbin, with the primary and secondary in separate sections? Surely this just unecessarily creates too much leakage inductance?
The split section bobbin is ferroxcube part number..
CSH-EP13-2S-10P
https://www.farnell.com/datasheets/1571206.pdf
The ferrite core is ferroxcube EP13, no gap.
Np=1; Ns=50
Why not use a single section bobbin, wind a full layer of secondary, then tape over it, then wind the single turn primary over the top of this?
