Why is an unloaded buffer showing an offset ?
anushaas
Member level 5
I am using an AD8041 IC as a buffer for a 0.2Vpp sinewave input at 1kHz from the function generator.The circuit is set on an NI Elvis II+ board.The buffer is unloaded but there occurs some offset at the output of the buffer.
Why is this happening?
Can you post a schematic?
Looking at the datasheet, you have an input offset voltage of 7 mV max. You also have an input bias current of up to 3.2 microamps (!). These could certainly cause an offset at the output of the buffer!
"some" offset is no value you will find in a datasheet.
Therfore we can not say if "some" offset is OK or not.
0.2Vpp and 1kHz are values you can calculate with, but unfortunately both don´t relate to the offset problem.
Klaus
This is the waveform at the input of buffer:
The output of unloaded buffer is as below:
your scope pictures are meaningless without schematic.
Klaus
no resistor involved?
What´s the source resistance of your frequency generator?
What happens when you measure without signal?
What says a DMM measurement?
Klaus
AD8041 closed loop gain for G=+1 is heavily peaking, with a bit of capacitive load or without the required supply bypass capacitors placed directly at the amplifier chip, you easily get self oscillations in the 100 MHz range. It could well explain the observed offset.
Suggestion: If you don't have the instruments to measure high frequency signals, don't use 100 MHz OPs.
Your schematic has nothing to supply the input bias current to the opamp. If it is the signal generator then its resistance will cause the offset voltage.
Add a same value resistor in series with the (-) input so that the bias currents cancel.
The Elvis II function generator has 50 ohms output, so it doesn't cause noticeable offset by it's impedance.
Perhaps we can see a photo that clarifies the complete test setup?
Thank you Sir.That helped.I put a pot in series to negative input,adjusted it till the offset is removed
it seems the input of your OPAMP was NOT free of DC.
And it seems the scope was not directely connected to the OPAMP input.
--> That´s why I asked about the DMM measurement.
The resistor my be around 50kOhms. This may affect upper cutoff frequency.
Your gain may not be flat anymore. Please check on this.
Klaus
If the amplifier wasn't oscillating before, it surely will now.
[Moved]How to remove DC offset from signal?
I am implementing the following schematic on a NI ELVIS II+ board
The wave form at point A in the schematic is shown below:
Initially,without a POT in the feedback path of OP1,the waveform at point B showed an offset as can be seen below:
Later,a 20k pot was introduced in the feedback path(shown in schematic) and it was adjusted to get the following waveform:
However,the waveforms at points C and D still show some offset as can be seen below:
Waveform at C:
Waveform at D:
How can I get rid of this offset?I tried introducing a 1uF capacitor in series before point C.
The waveforms at C and D obtained then were as follows:
Waveform at C:
Waveform at D:
How can this offset be eliminated?The circuit need to operate at a frequency range of 1Hz to 1MHz.The load shown in the
schematic is the maximum load.
The combination of the first C & D (4th and 5th) waveforms makes no sense. Either the oscilloscope has an offset error, or the output offset is changing when you connect the oscilloscope probe. In the latter case, it's most likely a case of high-frequent self oscillations, see my previous post #8. Also the distorted output waveform suggests an oscillation or other serious hardware problem.
My suggestion is to try a user friendly 10 to 20 MHz GBW OP in your circuit.
the measurement of input (A) and output (B) in configuration without feedback resistor do not fit either.
If the offset is caused by the bias current then you see it also in (A).
The deviation in offset voltage between input and output is max. 7mV per datasheet.
--> maybe the OPAMP is defective, or the measurement is wrong.
Is it a breadboard circuit? Do you have a good ground point with star connection?
Do you see strange signals when you change the x-axis timing to us/dev or ns/dev?
I don´t understand the second stage. It seems to be a difference amplifier, but then there is the C1/R4 combination feedback to non inverting input.
A feedback to non inverting input is always critical.
Klaus
One key assumption is that this particular part is
pristine. After checking that the supplies are what
you think they are, I'd swap out for another part
and see whether the issue persists, or changes.
A little handling ESD can really whack op amp input
attributes.
It's a classical Howland current source circuit. But a singular capacitor in the positive feedback branch without corresponding capacitor in the negative branch reduces the phase margin.
thanks for the info.
I just goggled about it and reviewed the schematic here.
In some schematics there is a feedback capacitor to the inverting input. This makes sense to stabilise the circuit.
--> But here is one to the non inverting input. @anushaas: please check on this.
The high bias current and offset voltage make the OPAMP not suitable for a current source.
Building a current source and feeding the signal to known resistors make - on the first sight - no sense.
I assume this is some kind of measurement circuit, and at least one resistor/impedance is unknown.
Klaus
