Why is a BJT called as 'current controlled device'?
Dineshkumar005
Newbie level 5
Newbie level 5
Coimbatore
1. Why is a BJT called as 'current controlled device'?
2. Why is a FET called as 'voltage controlled device'?
Re: BJT and FET - current and voltage controlled devices
That's the same:
ic = Iss eΛ(VBE/Vt) as you can see the collector current ic is controlled by vBE
iS = 1/2 k'n W/L (vGS - vT) here iS, source current, is controlled by vGS (for saturation operation)
in BJTs, the collector current can be controlled by base current Ic = (beta) Ib
in FETs, the drain source can be controlled by the channel voltage
